RG-S6930-2C Switches - 1
RG-S6930-2C Switches - 2
RG-S6930-2C Switches - 3
RG-S6930-2C Switches - 4
RG-S6930-2C Switches - 5
RG-S6930-2C Switches - 6
RG-S6930-2C Switches - 7
RG-S6930-2C Switches - 8
RG-S6930-2C Switches - 9
RG-S6930-2C Switches - 10
RG-S6930-2C – Next-Generation Data Center High-Density Centralized Modular Core Switch with 100GE/200GE Line Cards
Centralized modular core switch with large buffer and high-density ports in the 4-RU space, which is recommended for the data center gateway zone, MAN, and DCI
  • 100GE and 200GE line cards, and up to 144 x 100GE or 72 x 200GE ports
  • Straight front-to-rear airflow design, enhancing the cooling efficiency
Data Center 100GE/200GE DCI Core Switch RG-S6930-2C
Data center high-density core switch that supports 100GE/200GE line cards and provides 144 x 100GE or 72 x 200GE ports, which can be flexibly configured
Buffer of 16 GB and millions of routing connections due to its high performance, adapting to future expansion requirements on a data center network
Power
<2900W
Consumption Buffer
16G
Hardware-level Redundancy,
Ensuring Nonstop Services and Data Center Network Stability
With MACsec, the switch achieves interface-based secure line-rate transmission, effectively preventing data from being intercepted and obtained maliciously and
ensuring service data security.
RG-S6930-2C
28.8 Tbps
5400 Mpps
100GE/200GE ports
Expansion Module Slots
Two, each slot supporting the line card with up to 72 x 100GE ports or 36 x 200GE ports
Four power module slots, supporting 2+2 redundancy
Eight fan module slots, supporting 7+1 redundancy
Management Ports
One management port, one Console port, and one USB port
Dimensions (W × D × H)
442 mm x 760 mm x 175 mm (17.40 in. x 29.92 in. x 6.89 in., 4 RU)
33.55 kg (73.97 lbs., including eight fan modules and four power supply modules)
Input Voltage
AC
● Rated input voltage range: 100 V AC to 127 V AC (50 Hz to 60 Hz), rated input current: 12 A
● Rated input voltage range: 200 V AC to 240 V AC (50 Hz to 60 Hz), rated input current: 9.5 A
● Max input voltage range: 90 V AC to 264 V AC (47 Hz to 63 Hz)
HVDC
● Rated voltage: 240 V DC
● Rated input current: 8.5 A
Maximum Power Consumption
● Max: 2934 W
● Typical: 1338 W
● Static: 600 W
10% RH to 90% RH (non-condensing)
Working altitude
Software Specification
RG-S6930-2C
4094
L2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (basic QinQ and *selective QinQ), and GVRP
L3 Protocols
(IPv4)
BGP4, OSPFv2, IS-IS, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing, Routing Policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, and Any-RP
Neighbor Discovery, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, and IPv6 QoS
Static routing, ECMP, PBR, BGP4+, OSPFv3, IS-ISv6, RIPng, MLDv1/v2, PIM-SMv6, manual tunnel, *automatic tunnel, IPv4 over IPv6 tunnel, and * ISATAP tunnel
sFlow and IPFIX sampling
Data center features
Reporting buffer usage, queue traffic statistics, and packet drop statistics through gRPC
Hang prevention
MMU
Querying queue peak time
Displaying packet drop caused by insufficient buffer
Displaying the number of buffer alarms
Real-time buffer monitoring
Reading unicast packet drop caused by buffer congestion through MIB
IGMP Proxy、IGMP v1, v2, v3、IGMP host behavior、Querier election、Membership query and response、Static multicast route、IGMP fast leave、IGMP filter、IGMP v1 and v2 snooping、IVGL mode、Querier、Source IP address check、MLD proxy、MLDv1, v2、MLD snooping、MSDP、PIM-DM、PIM-SM v6(PIM-SM v6/PIM-SSM v6)、PIM-SMv4(PIM-SM/PIM-SSM)
ACL80、Dual-stack support for ACL、ACL-based redirection、IPv6 ACL、Standard IP ACL、Extended IP ACL、Extended MAC ACL、Ingress/Egress ACLs、Time-based ACL、Global ACL、Resource sharing in the case of applying an ACL on different physical ports or SVIs、ACL counter、ACL counter only、ACL logging、ACL re-marking、IPv4/IPv6 user-defined function(UDF) ACL、Displaying ACL resource usage、Expert-level ACL
802.1p, DSCP, and ToS priority mapping
Priority marking and remarking
Queue scheduling mechanisms, including SP, WFQ, and SP+WFQ
HA Design
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching, RLDP unidirectional link detection, 2+2 power redundancy, fan redundancy, and hot swapping for all line cards and power supply modules
Security Features
MACSec, Network foundation protection policy (NFPP), CPU Protection Policy (CPP), DDoS attack defense, unauthorized data packet detection, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 authentication for OSPF, RIPv2, and BGPv4 packets, uRPF, broadcast packet suppression, Telnet login and password mechanisms for restricted IP addresses
Management Modes
SNMP v1/v2c/v3, Telnet, Console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, and SPAN/RSPAN/ERSPAN
DHCP Client, DHCP Relay, DHCP Server, DNS Client, UDP Relay, ARP Proxy, and Syslog
*MPLS
MPLS L3VPN, SR, and SRv6
Specification
RG-S6930-2C
Take the following steps to configure an RG-S6930-2C switch:
  • Select an RG-S6930-2C chassis fully equipped with power supply and fan modules.
  • Select one or two line cards based on service requirements.
    Chassis and Supervisor Engine
    RG-S6930-2C
    RG-S6930-2C chassis equipped with four RG-PA1600II-F power supply modules and eight M2EFAN II-F fan modules
    Two expansion slots, four power supply module slots, and eight fan module slots
    Power Supply Modules
    RG-PA1600II-F
    1600 W power supply module (AC and 240 V HVDC)
    Fan Modules
    M2EFAN II-F
    Fan module (port-side intake)
    M6900-36CQ18DC-CES
    36 x 100GE QSFP28 ports and 18 x 200GE QSFP56 ports
    M6900-72CQ-CES
    72 x 100GE QSFP28 ports
    200GBASE Series Optical Modules
    200G-Q56-SR4-MM850
    200G SR4 module, QSFP56 form factor, MPO-12 connector, 100 m (328.08 ft.) over OM4 MMF
Fale conosco
Fale conosco
Fale conosco
Fale conosco
