Extended Transmission Range
Increased Power Capacity
Enhanced Power Supply
Dual-boot Redundancy
1+N Power Supply Redundancy
Fast onboarding
Port
96 Mps
Power module slot
Power module type
Frequency: 50 Hz to 60 Hz
Rated current per input: 8 A
SFP port
1000Base-X
100Base-X
SFP+ port
10GBase-R
1000Base-X
RTC
Power consumption
< 85 W
10% to 90% RH
5% to 95% RH
Temperature alarms
EMI
GB/T9254.1-2021 Class A
Safety standard
GB4943-2011
10 kg (22.05 lbs)
4K 802.1Q VLAN
MAC address-based VLAN
Basic QinQ
Time range-based ACL
Global ACL
Rate limiting on an interface
SP, WRR, SP+WRR, and RED/WRED
DHCPv6 snooping
DHCPv6 client
DHCPv6 relay
MAB
ARP rate limiting
SSH and SSHv2.0
Ring network protocol
IPv4/IPv6 static route
Routing Policy
Basic IPv6 protocols
Zero Touch Provisioning (ZTP)
CWMP (TR069)
RG-S5750-24 SFP4XS24DP-UP
Up to three power modules
RG-24DUP1DB48LC
OEHC-0.5-1000M
OEHC-1.5-1000M
Fale conosco
Fale conosco
Fale conosco
Fale conosco
