RG-S6150-24VS8CQ-X
and Network Connectivity
Guaranteed Data Transmission
Hareware Specifications
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
8 x 40GE/100GE QSFP28 ports
4 x fan modules
2.8 Tbps
4 Tbps
96,000 (default)
96,000 (default)
80,000 (default)
80,000 (default)
350,000 (default)
350,000 (default)
65,000 (default)
65,000 (default)
Ingress: 28,000
Egress:4,000
Number of VRFs
1,024
1,024
10 kg (22.05 lbs)
10 kg (22.05 lbs)
2.2 GHz quad-core processor
DDR4 4 GB
8 GB flash memory
DDR4 4 GB
8 GB flash memory
35 MB
35 MB
270 W
300 W
PA550I II-F:
PA550I II-F:
Frequency: 50/60 Hz
HVDC input: 240 V DC
AC input: 90 V AC to 264 V AC
Maximum operating altitude
5000 m (16404.20 ft.)
Software
RG-S6150-X Series
SVI: 4k supported
MCE
Stateless auto configuration
SSH
Hot swapping of fan modules
NTP an SNTP
RMON (1, 2, 4, 9)
Ruijie Could-based management
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
RG-S6150-24VS8CQ-X
8 x 40G/100G QSFP28 ports
4 fan modules
2 power supply module slots
RG-S6150-48VS8CQ-X
4 fan modules
RG-PA550I II-F
550 W AC power supply module
1000BASE-GT mini GBIC module
VG-SFP-SR-MM1310
100G-AOC-1M
Fale conosco
Fale conosco
Fale conosco
Fale conosco
