RG-MUX-8LC/LC Switches - 1
RG-MUX-8LC/LC Switches - 2
RG-MUX-8LC/LC Switches - 3
RG-MUX-8LC/LC Switches - 4
RG-MUX-8LC/LC Switches - 5
RG-MUX-8LC/LC Switches - 6
RG-MUX-8LC/LC Switches - 7
RG-MUX-8LC/LC Switches - 8
RG-MUX-8LC/LC Switches - 9
RG-MUX-8LC/LC Switches - 10
RG-MUX-8LC/LC All-Optical Modular 8-Port Transparent Distribution Device
  • CWDM technology with zero fiber splitting, providing exclusive indoor bandwidth of 10 Gbps
RG-MUX-8LC/LC 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded.
The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
8 x demultiplexing ports, supporting 1GE/2.5GE/10GE
1 x multiplexing port
1 x multiplexing port, supporting connection to a dual-uplink splitter
2 x uplink ports for optical splitting
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
Connector type
LC/UPC
LC/UPC
LC/UPC
149.0 mm x 140.5 mm x 22.0 mm (5.87 in. x 5.53 in. x 0.87 in.)
405 mm x 378 mm x 425 mm (15.94 in. x 14.88 in. x 16.73 in.)
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Mounting
Mounting on a wall or in a rack (cabinet)
Operating temperature: 0°C to 55°C (32°F to 131°F)
Storage temperature: –40°C to +85°C (–40°F to +185°F)
Operating humidity: 5% to 95% RH (non-condensing)
Same as the specification of the SOE switch
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
6 x transparent distribution device/dual-uplink splitter slots
442 mm x 50 mm x 58 mm (17.4 in. x 1.97 in. x 2.28 in.)
557 mm x 358 mm x 271 mm (21.93 in. x 14.09 in. x 10.67 in.)
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
Mounting
Operating temperature: –40°C to +85°C (–40°F to +185°F)
RG-MUX-8LC/LC
Building-side 8-port transparent distribution device, 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port
RG-MUX-8LC/LC-H
Building-side 8-port transparent distribution device (high-end version with low insertion loss), 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port, supporting connection to a dual-uplink splitter
RG-MUX-EXT
Building-side transparent distribution device's expansion module, or optical dual-uplink splitter (delivered with short fiber jumpers), which connects to the transparent distribution device and provides 1-to-2 optical signal splitting to realize dual-uplink networking; 1 x multiplexing port, 2 x uplink ports for optical splitting
RG-MUX-BOX
Building-side transparent distribution device subrack, 6 x transparent distribution device/dual-uplink splitter slots
CWDM Transceiver
  • CWDM transceivers are installed on core switches in the core equipment room, and are connected to the multiplexing port of the transparent distribution device through fiber trunk cables.
  • The access-side CWDM transceiver is installed on the access switch in the building's ELV room, and is interconnected with the demultiplexing port of the transparent distribution device through a short fiber.
SFG-LR-SM
Core switch side, 1G BASE-LR,SFG Transceiver, 8 different wavelengths (10 km, LC)
SFX-LR-SM
Core switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10 km, LC)
GE-SFP-LR(A1-4)-H
Access switch side, 1G BASE-LR, SFG Transceiver, 4 different wavelengths (10 km, LC), used in dual uplink scenarios
GE-SFP-LR(A1-8)-H
Access switch side, 1G BASE-LR, SFG Transceiver, 8 different wavelengths (10 km, LC), used in dual uplink scenarios
XG-SFP-LR(A1-4)-H
Access switch side, 10G BASE-LR, SFP+ Transceiver, 4 different wavelengths (10 km, LC), used in dual uplink scenarios
XG-SFP-LR(A1-8)-H
Access switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10 km, LC), used in dual uplink scenarios
Fale conosco
Fale conosco
Fale conosco
Fale conosco
