RG-MUX-8LC/LC-H Switches - 1
RG-MUX-8LC/LC-H Switches - 2
RG-MUX-8LC/LC-H Switches - 3
RG-MUX-8LC/LC-H Switches - 4
RG-MUX-8LC/LC-H Switches - 5
RG-MUX-8LC/LC-H Switches - 6
RG-MUX-8LC/LC-H Switches - 7
RG-MUX-8LC/LC-H Switches - 8
RG-MUX-8LC/LC-H Switches - 9
RG-MUX-8LC/LC-H Switches - 10
RG-MUX-8LC/LC-H Switches - 11
RG-MUX-8LC/LC-H Ethernet All-Optical Modular 8-Port Transparent Distribution Device Used with Splitters
Paired with splitters to realize dual uplinks on network links and suitable for scenarios with dual core switches
  • Combination of splitters and transparent distribution devices, achieving dual uplinks for all-optical links and improving the link reliability between the core network and building
  • CWDM technology with zero fiber splitting, providing exclusive indoor bandwidth of 10 Gbps
RG-MUX-8LCI/LC-H 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded. The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
Combination of Splitters and Transparent Distribution Devices Achieving Dual Uplinks for All-Optical Links,
Improving Link Reliability Between the Core Network and Building
The 8-port modular transparent distribution device together with splitters evenly distributes the optical power in a 50:50 ratio to two separate links. This setup allows for dual-uplink networks, effectively enhancing the reliability of the links between the core side and access side.
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
8 x demultiplexing ports, supporting 1GE/2.5GE/10GE
1 x multiplexing port
1 x multiplexing port, supporting connection to a dual-uplink splitter
2 x uplink ports for optical splitting
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
Connector type
LC/UPC
LC/UPC
LC/UPC
149.0 mm x 140.5 mm x 22.0 mm (5.87 in. x 5.53 in. x 0.87 in.)
405 mm x 378 mm x 425 mm (15.94 in. x 14.88 in. x 16.73 in.)
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Mounting
Mounting on a wall or in a rack (cabinet)
Operating temperature: 0°C to 55°C (32°F to 131°F)
Storage temperature: –40°C to +85°C (–40°F to +185°F)
Operating humidity: 5% to 95% RH (non-condensing)
Same as the specification of the SOE switch
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
6 x transparent distribution device/dual-uplink splitter slots
442 mm x 50 mm x 58 mm (17.4 in. x 1.97 in. x 2.28 in.)
557 mm x 358 mm x 271 mm (21.93 in. x 14.09 in. x 10.67 in.)
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
Mounting
Operating temperature: –40°C to +85°C (–40°F to +185°F)
RG-MUX-8LC/LC
Building-side 8-port transparent distribution device, 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port
RG-MUX-8LC/LC-H
Building-side 8-port transparent distribution device (high-end version with low insertion loss), 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port, supporting connection to a dual-uplink splitter
RG-MUX-EXT
Building-side transparent distribution device's expansion module, or optical dual-uplink splitter (delivered with short fiber jumpers), which connects to the transparent distribution device and provides 1-to-2 optical signal splitting to realize dual-uplink networking; 1 x multiplexing port, 2 x uplink ports for optical splitting
RG-MUX-BOX
Building-side transparent distribution device subrack, 6 x transparent distribution device/dual-uplink splitter slots
CWDM Transceiver
  • CWDM transceivers are installed on core switches in the core equipment room, and are connected to the multiplexing port of the transparent distribution device through fiber trunk cables.
  • The access-side CWDM transceiver is installed on the access switch in the building's ELV room, and is interconnected with the demultiplexing port of the transparent distribution device through a short fiber.
SFG-LR-SM
Core switch side, 1G BASE-LR,SFG Transceiver, 8 different wavelengths (10 km, LC)
SFX-LR-SM
Core switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10 km, LC)
GE-SFP-LR(A1-4)-H
Access switch side, 1G BASE-LR, SFG Transceiver, 4 different wavelengths (10 km, LC), used in dual uplink scenarios
GE-SFP-LR(A1-8)-H
Access switch side, 1G BASE-LR, SFG Transceiver, 8 different wavelengths (10 km, LC), used in dual uplink scenarios
XG-SFP-LR(A1-4)-H
Access switch side, 10G BASE-LR, SFP+ Transceiver, 4 different wavelengths (10 km, LC), used in dual uplink scenarios
XG-SFP-LR(A1-8)-H
Access switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10 km, LC), used in dual uplink scenarios
Fale conosco
Fale conosco
Fale conosco
Fale conosco
