RG-S7620-20SFG2CQ Switches - 1
RG-S7620-20SFG2CQ Switches - 2
RG-S7620-20SFG2CQ Switches - 3
RG-S7620-20SFG2CQ Switches - 4
RG-S7620-20SFG2CQ Switches - 5
RG-S7620-20SFG2CQ Switches - 6
RG-S7620-20SFG2CQ Switches - 7
RG-S7620-20SFG2CQ Switches - 8
RG-S7620-20SFG2CQ Switches - 9
RG-S7620-20SFG2CQ Switches - 10
RG-S7620-20SFG2CQ Switches - 11
  • Twenty SFG ports (equivalent to 160 SFP channels) and two 100GE uplink ports, backward compatible with 40GE, and allowing flexible configuration
Twenty SFG hyper-converged ports are provided with each supporting up to eight SFP channels. This supports connections for up to 160 devices simultaneously. High-density connections can be established in this 2 U switch, and two 100GE QSFP28 uplinks and one expansion slot for connecting devices such as servers and regular switches are available to support diversified configurations.
and High Performance
Hot-swappable Redundant Power
Hot-swappable Redundant Fan
Quick onboarding
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Module service port
M7600-4GT4VS:
● 4 x 10/100/1000BASE-T ports
● 4 x 25GE SFP28 ports
M7600-2CQ:
M7600-2CQ
M7600-4GT4VS
RG-PA550I II-F
S7610-FAN I-F
S7620-FAN I-F
System specifications
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Packet forwarding rate *1
714 Mpps
1786 Mpps
833 Mpps
2976 Mpps
960 Gbps
2.4 Tbps
1.12 Tbps
4 Tbps
8 GB
4 GB DDR4
36 MB
128,000
96,000
4000
65,000
Ingress: 28,000
Egress: 4,000
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
RG-PA550I II-F (AC input):
RG-PA550I II-F: 550 W
Module power consumption
270 W
450 W
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
9.73 kg (21.45 lbs)
14.4 kg (31.75 lbs)
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Front-to-back airflow
27°C (80.6°F): 56 dB
45°C (113°F): 72 dB
Module hot swapping
Fan failure alarm
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IEC 62368-1: 2018
EN 62368-1: 2014+A11:2017
EN 55032:2015+A1:2020
EN IEC 61000-3-2:2019+A1:2021
EN 55035:2017+A11:2020
EN 300386 V2.2.1
Ordering Information
Device Model
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IP service
Static ARP
GRE tunnel
IPv4/IPv6 static routing
Graceful restart (GR)
IPv4 IS-IS
IPv6 IS-IS
PIM-SM
PIM-DM
Port-based rate limiting
RSPAN and ERSPAN
FTP and S TFTP
VLAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
VXLAN EVPN
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
    RG-S7610-10SFG2CQ
    RG-S7610-10SFX2CQ
    RG-S7620-20SFG2CQ
    RG-S7620-20SFX2CQ
    M7600-2CQ
    M7600-4GT4VS
    RG-PA550I II-F
    1GE Optical Transceiver
    40GE Optical Transceiver
    100GE Optical Transceiver
    CWDM Transceiver
    SFG-LR-SM
    SFX-LR-SM
Fale conosco
Fale conosco
Fale conosco
Fale conosco
