RG-S6110-48MG4VS2QXS-UP Switches - 1
RG-S6110-48MG4VS2QXS-UP Switches - 2
RG-S6110-48MG4VS2QXS-UP Switches - 3
RG-S6110-48MG4VS2QXS-UP Switches - 4
RG-S6110-48MG4VS2QXS-UP Switches - 5
RG-S6110-48MG4VS2QXS-UP Switches - 6
RG-S6110-48MG4VS2QXS-UP Switches - 7
RG-S6110-48MG4VS2QXS-UP Switches - 8
RG-S6110-48MG4VS2QXS-UP Switches - 9
RG-S6110-48MG4VS2QXS-UP Switches - 10
RG-S6110-48MG4VS2QXS-UP Switches - 11
RG-S6110-48MG4VS2QXS-UP Switches - 12
100/1000/2.5G/5GBASE-T ports, PoE/PoE+/PoE++, 4 x 25G SFP28 ports and 2 x 40G QSFP+ ports, offering flexible networking options to build high-performance campus networks
  • 48 x 100/1000/2.5G/5GBASE-T ports for access, 4 x 10GE/25GE SFP28 ports and 2 x 40GE QSFP+ ports for uplink, meeting high bandwidth demands of large campuses
48 x 100/1000/2.5G/5GBASE-T ports and 4 x 25GE and 2 x 40GE uplink ports are provided to realize flexible networking.
RG-S6110-24MG4VS-UP
RG-S6120-24XMG4XS4VS-UP-H
RG-S6120-48XMG4VS2QXS-UP-H
Not Supported
Not Supported
Not Supported
RG-S6110-24MG4VS-UP
392 Mpps
678 Mpps
750 Mpps
982 Mpps
528 Gbps
912 Gbps
1008 Gbps
1320 Gbps
Egress: 1,000
RG-S6110-24MG4VS-UP
Fixed power supply: 460 W
The maximum power is 370 W.
90 W (without PoE)
● 1 x RG-PA600I-P-F:450 W
● 2 x RG-PA600I-P-F:930 W
● 1 x RG-PA600I-P-F:400 W
● 2 x RG-PA600I-P-F:880 W
150 W (without PoE load)
1,800 W (full PoE load)
200 W (without PoE load)
RG-S6110-24MG4VS-UP
3.71 kg (8.18 lbs)
5.37 kg (11.84 lbs)
RG-S6110-24MG4VS-UP
27°C (80.6°F): 40 dB
Maximum value: < 78 dB
27°C (80.6°F): 60 dB
Automatic speed adjustment
RG-S6110-24MG4VS-UP
Software Specifications
RG-S6100 Series
Stateless Auto Configuration
GR for RIP, OSPF, and BGP
Ruijie Could-based management
RG-S6110-24MG4VS-UP
25GE
Fale conosco
Fale conosco
Fale conosco
Fale conosco
