RG-S5350-24GT4XS-E Switches - 1
RG-S5350-24GT4XS-E Switches - 2
RG-S5350-24GT4XS-E Switches - 3
RG-S5350-24GT4XS-E Switches - 4
RG-S5350-24GT4XS-E Switches - 5
RG-S5350-24GT4XS-E Switches - 6
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-12GT4XS-P-E
RG-S5350-24GT4XS-P-E
RG-S5350-48GT4XS-P-E
Fixed service ports
4 x 1GE/2.5GE/10GE SFP+ ports
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
94 Mpps
125 Gbps
DDR4 1GB
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Unit weight
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Mounting
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fixed power supply: 40 W
Leakage current
≤ 3.5 mA
Built-in power supply: 409 W
35 W (without PoE load)
405 W (full PoE load)
52 W (without PoE load)
Leakage current
≤ 3.5 mA
The maximum power is 370 W.
The maximum power is 405 W.
supported
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fanless, quiet, < 20 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-E Series
PIM SMv6, and PIM-SSMv6
Extended IP (hardware ACLs
IPv6 ACLon IP addresses)
Multiple AAA modes
BFD, NSR, VRRR, VRRP+
Basic LACP
SPAN, RSPAN
CLI (Telnet/Console)
1:1 mirroring
N:1 mirroring
1:N mirroring
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fale conosco
Fale conosco
Fale conosco
Fale conosco
